Rear drum to disc conversion plates
Old Nov 25, 2003 | 02:41 AM
Scarebird's Avatar
Car: 1998 Z28 convertible
Transmission: 700-R4
As you well know, the axle housing ends of rear drum and rear disc Third gens are different. I am marketing a set of caliper mount plates that will allow you to use 1980-85 Eldorado calipers and rotors (10.5"). This combination will allow you to use 14" rims also. Caliper cores are plentiful in the boneyard (needed for parking brake brackets and levers), as are prop valves. If you are interested in a pair, e-mail me at:
res086iw@verizon.net
They should run about $85, much cheaper than the Baer pieces
jaridjohn
Jul 8, 2024 03:49 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
