make it lift?
Old Dec 3, 2003 | 11:17 AM
icebird_1981's Avatar
make it lift?
hey i have watched alot of races and i see thirdgens front ends come right up off the ground? what do they got under there hood? and what do i have to do to get the front of my car come right off the ground? i no that there is some special springs that lift up easy come down hard to transfer the power to the back.
can u guys give me info on what is needed i want to get my car to lift off the ground nothing amazing maby lke 5inchs
thanks
Old Dec 3, 2003 | 12:08 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Moved to the suspension forum.
Old Dec 3, 2003 | 12:09 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: make it lift?
thanks
Its all in the weight transfer of the car. In short, drag struts for the front, drag shocks for the back, drag springs up front, as little weight as possible on the front of the car (move as much of that weight to the back as possible) and a set of super sticky tires and you will have a start. A lot of guys in some of the stock classes pull the tires with 350 horsepower. You may get better results in the organized racing boards though.
Old Dec 4, 2003 | 10:13 AM
ATOMonkey's Avatar
They have midgets under the car that push it up on launch. If you look really close, you can see their feet. I'd recomend at least three midgets under the hood for your application, because thridgens are so heavy.
We only needed one midget for our Pinto. It was really light and had a short wheel base, so the little guy didn't have to do too much work.
Old Dec 4, 2003 | 10:29 AM
nolanr0413's Avatar
Car: Trans am
tons of hp and big slicks
Old Dec 5, 2003 | 03:00 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
blackroc68
Sep 1, 2015 08:01 PM
mz92274
Aug 25, 2015 08:47 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
