What are the side effects of no coil spring isolators?
Old Dec 9, 2003 | 10:34 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
My dad seems to be convinced that without the coil spring isolators the metal/metal contact will wear through the car..... is this at all possible? I have a pair of new isolators that he wants me to put in.. but i mean, they're so thin anyway... seems like all they really do is keep everything quiet. Can anyone enlighten me? Plus, if I have it all apart again... I'm very tempted to lower it more with intrax springs, but it will probably make my front lip scrape, and I HATE seeing camaros with the scraped up front lip.
Old Dec 9, 2003 | 10:43 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i have no rear isolators in, i have checked the tops of the springs and the spring perch on the body and there is NO wear. the top of the spring looks brand new, it doesnt move or anything in that area when the cars weight is on them. when i buy my tubular A arms im removing the frnts aswell.
Old Dec 9, 2003 | 10:44 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
oh yeah, im also running the sportline springs. this is how it sits:
Old Dec 9, 2003 | 11:44 PM
Hg's Avatar
Hg
Car: '87 Z
do you think that the fronts would show the same amount of wear? Being the weight from the engine and all....
Old Dec 10, 2003 | 08:59 AM
MdFormula350's Avatar
the fronts are so tiny that all they would do is keep noise down if anything, the rear ones look like for some reason they support that area some, they are heavy and have like rubber and metal inside
Old Dec 10, 2003 | 09:02 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
look at the shape of the isolater, it is designed so that it distributes the weight across the whole top coil, not just a single contact point.
Old Dec 10, 2003 | 09:38 PM
OMINOUS_87's Avatar
Cut up a piece of garden hose, and tape it up real good to the top of the springs.
That will stop any metal to metal marring and prevent rust.
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
TA8487
Aug 11, 2015 09:02 PM
