What Adj Brake Prop Valve togo with?
Old Dec 17, 2003 | 11:42 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
What are you guys running as far as prop valves? I am going to be redoing all 4 corners with new calipers/rotors and I wanna make sure the balance is nice and even. Also how easy is the install, or is it easy at all???
Will
Old Dec 17, 2003 | 11:50 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Take a look at this.
https://www.thirdgen.org/newdesign/tech/propvalve.shtml
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
