Help With 4th Gen Rear And Earls SS Lines!
Old Dec 20, 2003 | 04:30 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Not sure if the part I got was correct. I ordered it from Spohn and they said it would work with my stock fronts and 4th gen rear. I think I should have gotten this? http://www.spohn.net/product.cfm?productid=1427 Anyone know the actual Earls PN on this item? The reason Im asking this is because I'm having trouble with the left rear axle brake line fitting into the T on the axle (its leaking). I noticed that on the axle lines, it looks to be an inverted flare? (dont know much about brake lines), and the T looks like it works with bubble flares???. The right rear brake line on the axle is working properly, but could the leaking on the left be due to a faulty axle line and not the Earls T? Any ideas? Someone please educate me. Thanks, Efrain.
Old Dec 21, 2003 | 02:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
take a ride to the dealer and see what it cost to replce all the hard lines for the brakes. It might be cheap as hell for them. I went to the dealer for TPI fuel lines and I paid $17 for them. THose where the ones that go from the tank to the engine. both feed and return. Just see what they cost, youd be surprised how cheap some stuff is for our car from the dealer.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
