front sway bar and drag racing...
Old Dec 20, 2003 | 05:55 AM
jon_volk's Avatar
i was thinking..other than the weight savings, i know that removing the front sway bar on a drag car allows better traction by letting the left and right sides of the front end rise at different rates keeping the rear planted...
now wouldnt it seem that this is just a crutch for a rear end that isnt set up 100% correctly....in theory, wouldnt a well set up rear suspension negate any adavantage of removing the sway bar
Old Dec 20, 2003 | 07:17 AM
ede's Avatar
ede
in theroy it sounds good, but why spend the time, effort, and money to over come the negative effects of having a front sway bar when you can remove it with very little effort, time, and zero money.
Old Dec 20, 2003 | 08:33 AM
jon_volk's Avatar
to have a car thatll hook and also not have a ton of body roll around curves. even w/ nice soft v6 springs (in a v8 car) up front a hollow 1le sway bar would make the car alot more stable...i dunno, i just like haveing a car thatll stick on the strip but also be a pleasure to drive on twisty back roads...nothing that id want to autocross or road race with, but something thatll stay relatively flat on a curve.
Old Dec 21, 2003 | 03:52 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
it works beause it allows more suspension travel in the front end, giving the car better weight transfer.
Old Dec 24, 2003 | 11:50 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
does anybody here have comparitive times of their car with and without the front sway bar?
Old Dec 24, 2003 | 12:13 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I personally felt no difference in handling when I removed mine this spring-hey I even had my original radials on too to flog around on for fun-kinda miss lettin the rear end hang out on occasion
Anyways, my personal scenerio was consistent 1.82-.83's into the high 1.7?-1.80
Ever car will be different depending on way too many factors to start listing. I've always been fortuante with my car as it's always transfered great-actually pulled the tires on a few occasions with these cruddy 60's. Then I've seen other guys with the same worn out suspensions pull 1.8-1.9-2.0 and then others as low as 1.5's So there's more at work than the swap bar.
As stated above, for the cost-it's a no brainer and I could tell no difference in handling.
Old Dec 24, 2003 | 01:21 PM
MdFormula350's Avatar
i didnt see much gained after i took off my front bar but i still cant hook when launching, i am sure i will gain traction from weight transfer when i start hooking up better like with drag radials.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
