9-Bolt / 9" Same thing?
Old Dec 27, 2003 | 08:41 AM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
I am getting ready to order lower control arm relocation brackets from Spohn. It has the following note:
Note: For installation on stock rear or Strange Engineering 12 bolt rear. If you have a Moser Engineering 12 bolt or Ford 9" rear, use our Part # 210-M relocation brackets.
I have a 9-Bolt rear end. It is a 'stock' rear end but it didn't come on my car. I bought it in a salvage yard off of an earlier model Firebird. Is '9-Bolt' and '9-Inch' the same thing? If not, wich brackets do I need to order? Thank you for your help.
Old Dec 27, 2003 | 08:44 AM
MdFormula350's Avatar
9 bolt is a thirdgen rear end, 9 inch would be a ford rear end, but people do put 9 inch ford rear ends in.
u want these http://www.spohn.net/product.cfm?productid=1290
9 bolt is a stock rear end.
Old Dec 27, 2003 | 11:08 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
9 bolt borgwarner and ford 9" are two totally differnt rear axles
however other companys do use the borgwarner model 78 differential. for instance nissan uses it in their skyline and ford uses it in their new escapes. the borgwarner model 78 axle is the "9 bolt" to us thirdgeners.
Old Dec 27, 2003 | 07:53 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You sure about the skyline, I could have sworn the skyline had an independent rear.
Old Dec 28, 2003 | 12:10 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
he's talking about just the differential, not the whole rearend.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
