Jacking Question
Old Dec 27, 2003 | 01:32 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Jacking Question
where exactly are you supposed to jack the front end up with the spare tire jack? and how do you guys get a floor jack under the front airdamn to jack the car up?
Old Dec 27, 2003 | 02:16 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I slide the floor jack between the front side of the tire and the back side of the front air dam. It just fits. It'a a pain to pump it enough times to get it off the ground, but it works.
I use the front frame rails before the trans crossmember in the front, and the rear framerails just in front of the LCAs in teh back as jackstand points.
I jack up the rear using the rearend.
Old Dec 27, 2003 | 03:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's where the factory's instructions say to put their jack that comes with the spare tire.
Not the best place to jack it for general service; but OK for roadside emergencies I guess.
Old Dec 27, 2003 | 08:03 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
on the front I jacked up my car yesterday next to a circle looking piece... My friends dad told me what it was but I forgot. Its alot better safe than sorry. Dont wanna **** anything up.
nate
Old Dec 27, 2003 | 11:55 PM
joshwilson3's Avatar
Old Dec 28, 2003 | 07:32 AM
92MaroRS's Avatar
well i saw them on the back but didnt see em on the front so i just used the subframe to jack it up. i needed to get my tires off so i can finish polishing up the rest of my rims.
Old Dec 28, 2003 | 10:02 AM
The tabs that hang down work fine for the factory jack that has the poroper head on it, but I wouldn't use the same point for a floor jack, unless you have an adapter specifically for this purpose. The adapters are available from the Eastwood Company, and several other tool suppliers. This will keep you from smashing in the floorpans when you jack up the car.
Old Dec 29, 2003 | 12:19 AM
91Z28-350's Avatar
I use 2 floor jacks. A small 2 ton jack, which I use under my subframe connectors (which run along the rails), to jack it up high enough so that I can get my 3 ton jack under, I raise the body about 3 inches first. I then jack up the front via the a-arms first. Sometimes I use the front k-member, but not as often. If using the k-member I have to jack it up higher. I use the a-arms because it's easier to lower and raise directly to the ground. I can drop the car to the ground with the a-arms, but I don't have enough room to pump the jack up, which is why I use the second jack.
Old Dec 30, 2003 | 03:10 AM
Kandied91z's Avatar
a stock k member is good for the front if you can get too it. not a tubular though. the points described above are all very good. i use the point described right behind the front wheels for the front since all my pieces are tubular and the rear end for the rear. i use to use 2x4's to drive up and get that extra lift for the jack to fit when i used lowering springs.
Old Dec 30, 2003 | 05:35 AM
92MaroRS's Avatar
thanks for the advice guys. it will come in handy this spring when its time to install some stuff.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
92GTA
Apr 9, 2016 07:39 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
