bleeding ABS brakes
Old Dec 27, 2003 | 04:31 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
bleeding ABS brakes
Bleeding ABS drums.. any ideas or what to d. i was told to lower the car all way down in the back and let them gavity bleed? is this true. ther 92 GM
Old Dec 27, 2003 | 05:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no 3rdgens have ABS from the factory.
if you mean you have a rear thats from a car that had ABS.... its like any other brake bleeding.
my personal pref is speed bleeders ( www.speedbleeder.com ) but the usual 2 person open/close with foot on the pedal works too... or any other "normal" method.
the only thing diffrent with ABS cars is that air can become trapped in the ABS unit. depending on the exact setup there may be extra bleeders on the ABS unit, it may be need to be reversed pressure blead, ect....
the rear brakes (disc or drum) and front calipers in a ABS equipped car are the same basic design as non ABS cars.. no diff in bleeding...
Old Dec 27, 2003 | 09:15 PM
Engine: peanut LB9
thank you, i have a rer end out of a 96 w/ ABs and wasn't 100% sure about how t do this, plus for future refrence on another car,
like a 92 cav. w/ ABs
Old Dec 28, 2003 | 05:52 PM
joshwilson3's Avatar
Old Dec 30, 2003 | 12:07 AM
RJR99SS's Avatar
the abs unit usually has a diagnostic self bleeding procedure that can be activated by a scanner. It's a pretty dang neat thing.
Old Dec 30, 2003 | 12:16 AM
TwinTurboROC's Avatar
in my years so far as a mechanic (5) i have never seen a ABS UNIT bleed itself... do explain... i am intrigued? (not ment to be a dick comment either) but i do need a model make and year of the car or the make of the abs unit also.
Old Dec 30, 2003 | 12:18 AM
RJR99SS's Avatar
really?
I've done it a few times even as a lowly lube tech. With a tech 2 scanner you can access the bleeding procedure. I cant give you an exact description.
But i've done it and seen it done plenty of times. If you hold your foot on the brake pedal you'll feel it moving by itself. It's a pretty strange feeling.
The last one i remember doing it on was a 97 or so suburban.
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 19, 2015 08:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
