vibration is still there!!!!!
Old Dec 28, 2003 | 05:24 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
alright, i had a really bad vibration in the front of the car that started at about 65 and got worse as you go faster. Today i replace my front struts with KYB GR-2, strut mounts, and a bad sway bar end-link. The stupid vibration is still there, and i don't know what it is. The ball joint's (at least that's what i think they are) didn't look too good, could those cause the vibration? thanks for any help
Old Dec 28, 2003 | 07:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try swapping the tires front to rear.
Old Dec 29, 2003 | 05:05 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Yeah, try rotating your tires. Be sure to check to see if you have axel specific rims before you move them around.
Old Dec 29, 2003 | 03:43 PM
84 t/a 5.0's Avatar
yeah, i rotated them already, but that was before i did this work. maybe i'll do a cross-rotation
Old Dec 29, 2003 | 04:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It'll stay in the front if you cross-rotate them.
Rotate them from front to rear.
Of course, you could also have bent wheels, maybe even more than one.
Old Dec 29, 2003 | 07:01 PM
84 t/a 5.0's Avatar
yeah, i hope their not bent
Old Dec 29, 2003 | 11:10 PM
Wezzeles's Avatar
Car: Camaro
ive heard its from the driveshaft. my 92 Rs does the same thing at 65 mph and higher. the driveshaft isnt balanced properly or something but it vibrates at high rpms and thats what you feel. someone confirm this.
Old Dec 30, 2003 | 01:16 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
check your strut mounts. They tend to wear out. I know it was a major source of vibration in my Camaro. Though the new shocks diminished it quite a bit.
Old Dec 30, 2003 | 01:36 AM
84 t/a 5.0's Avatar
thanks for the replies. i replaced both strut mounts, so that's not it. I'll check on the driveshaft
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
