Tie rods rubbing the wheel.
Old Jan 5, 2004 | 02:21 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
I just replaced the front steering linkage and suspension along with a set of wheels and tires. Now the outer tie rods are rubbing on the 17X9.5" ZR1's. What can I do to remedy this? I know the bumpsteer kit is available, but I remember someone posted that it didnt work with the 17X9.5" Ronal Firehawks, so Im not sure. Any help is appreciated. Thanks, Efrain.
Old Jan 5, 2004 | 03:03 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Are they rubbing badley? If its just a bit, you can grind some of the tie rod down. Or install a slim spacer.
Old Jan 5, 2004 | 08:07 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you'll need to get the adapters from www.skulte.com to fit the wheels properly. they will not directly bolt on.
Old Jan 18, 2005 | 03:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have the same issue and it is rubbing slightly on the pass side.
So grinding them down a bit is fine?
I am running 2" Skulte spacers and 17x9.5" AFS ZR1 wheels.
EDIT: I just noticed teh date was 2004.
Old Jan 18, 2005 | 06:31 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
A little grindage is fine, just don't get too crazy with it. Steering parts are the LAST thing you want breaking while you're doin' 90.
Old Jan 18, 2005 | 06:40 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
well this may sound a little stupid but i no that my stock 16" 91 rs rims arent interchangable front to back and i found that out the hard way when i attempted to rotate my tires and grinded off the insides of both rims, pretty cool huh? well im not sayin this is your problem and i just noticed the post about the spacers that mrr23 made. just an idea tho
Old Jan 18, 2005 | 06:46 PM
Zepher's Avatar
Well, grinding them worked fine.
I took the car around the block again with the new wheels and tires and let me tell you, cold road racing tires plus cold asphalt equals no traction whatsoever. Wheels are fitted with 275/40/17 Nitto 555R II Extreme racing tires.
Old Jan 19, 2005 | 02:22 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Wow back from the dead!
I cant believe Ive had had my wheels for over a year now?! Well, the rubbing ceased after a bit of grinding but not before some damage to my ZR1's. I do get some rubbing when the wheel is turned all the way to the lock. Gotta get that steering box installed
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
