passenger front brake line which part of mc go into?
Stupid question but i broke front brake line on passenger side happened after fire under car anyways i tried fix brake line my self and ran brake line from passenger side to master cyl however i took educated guess as couldnt find anything in haynes or chiltons. I left old brake line in place just broke off the other end and used socket get it off the left side far back towards firewall looked like was line leading to passenger side hooked it up nopw brake lightstill lights up was this the wrong hose i snapped off mc? tried pulling old brake line all the way out but clamped under car soo much i have no idea if i just messed my car up worse? by unhooking wrong line from mc any help? thanks in advance 85 camaro berlientta if that helps 305v8
ok so i mis typed name part its probality the porpotioning valve like you saying which is under master cylinder however there is two brake lines one close to fire and one just in front of it im confused as to which one is for right side which one is for left they all twisted tangld etc whoever replaced brake lines before routed them in some messed up ways im just trying to clean up mess and have everything where it should be
<html>thanks thats how i did it just however looked lil different in a picture of book my friend had looked like it was coming from the front of the porpotioning valve and the back was for rear i put it on the back left i have no clue what the front grey brake line is for looks like brake line going take it midas have them check everything out as i bled the brakes and still getting brake light
the line that is in area i marked in picture this is what i dont know what is for any help/?(img src=:http://www.geocities.com/boredinva2001/eng.jpg"></a></html>
