What 12 bolts will fit 82-92 fbody?
Old Jan 11, 2004 | 07:31 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Im looking to find a posi 12 bolt not a moser or a strange, one from a maybe a truck or one i can find in a yard. What should I look for to fit my car... ford 9 or 12 bolt?
Old Jan 11, 2004 | 08:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
none fit into a thirdgen without a lot of modification
Old Jan 12, 2004 | 04:50 AM
ede's Avatar
ede
if you don't want moser or strange try currie
Old Jan 12, 2004 | 07:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: What 12 bolts will fit 82-92 fbody?
niether of them ever came from the factory for these cars.
you would need to get one, possibly have it shortend to the correct width, then have brackets welded on the tubes so you could bolt it up... then machine some kind of torque arm adapter so you can connect that...
but thats alot easier said then done... thats why theres aftermarket ones like you mentioned..
if you dont have the skill or tools to make it, you could get just the housing and axles from them, and then pull a 9" from the 'yard and do it that way... save ya a few hund...
Old Jan 12, 2004 | 08:08 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
if you are wanting a 12 bolt that will fit length-wise in a 3rd gen you will need to get one from a 64-66 el camino,66-72 nova,or a 67-69f-body,then you will need to have your 3rd gen spring pads welded onto this 12 bolt and call summers brothers to get the bracket craddle that mounts the torque arm,you should be able to get this set up under your car for 400.00 then add your gear and posi unit of choice...
Old Jan 12, 2004 | 03:32 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
You can also use a 9" Ford rearend from a '67-68 Mustang and make all the modifications to it that gen3z mentioned above.
I've had one in my garage for years with the intention of putting it in my car. The torque-arm bracket won't be necessary in my case because I'm using a South Side Machine rear suspension.
Old Jan 12, 2004 | 04:03 PM
gen3z's Avatar
the only reason i never mention the 9"is its quite heavy and the rolling resistance in this rear will slow your car down you need to add roughly 50hp to run the same e.t.,unless of course you purchase the strange eng.3rd member that uses the gm 12bolt gears so now you have spent nearly 1600.00 on this unit,passed the budget for me!
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
89lsc
Aug 14, 2015 04:58 PM
