Mmmm...KYB struts are yummy!
Old Jan 12, 2004 | 07:00 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Just wanted to post my opinion of my ride after installing the KYB GR-2 struts. I installed Eibach prokit springs about 1.5 yr ago. Had new stock struts on after spring installation. Kicking myself now for not putting on better struts when I did my springs. The KYBs are great. My front end was definately missing something. This really filled the gap.
For what its worth......
Old Jan 12, 2004 | 07:04 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I think we all wanna know what they tasted like though ... hehe.. just kidding
KYB eh. Where did you by them from?
Old Jan 14, 2004 | 07:30 PM
Summit...I don't think Jegs had em. Sure...$100 for both, but what the hell. The made a great improvement.
Old Jan 15, 2004 | 12:57 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i've heard alot of bad stuff about the kyb's and thats the cheapest performance struts/shocks i can find. Glad to hear something positive about them. im going with the pro kit also
Old Jan 15, 2004 | 03:59 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
87CIZ,
What bad things, exactly?
Matt
Old Jan 15, 2004 | 07:53 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've used the kyb gr-2 struts with gas-a-just shocks combination in my old '88 bird and they're a really great setup... Give the car a nice feel..
Old Jan 15, 2004 | 09:05 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have kybs, and other then its a harsher ride (over blown stocks at 200k) I have no problem with them. Sure their no konis or belistines (sp?).
Old Jan 16, 2004 | 04:35 AM
Spdfrk1990's Avatar
imo for a stiff spring they suck but if ur runnin the pro kit or stock springs there prob ok. I have the gr2 struts on the front with hotchkis and im not happy with them i want bilsteins.
Old Jan 16, 2004 | 05:06 PM
I cant compare to koni or bilstein, but they are MUCH better than the stockers I had with the prokit. And the stock struts only had 20K on them. I'm sure they aren't the best, but hey, I'm a poor med student.
Old Jan 16, 2004 | 07:01 PM
Kandied91z's Avatar
anything is going to be better then your worn out stock pieces....try some bilsteins and you'll never go back.
Old Jan 17, 2004 | 10:28 AM
PGdynamics's Avatar
Car: 1987 IROC Camaro Z28 G92
Engine: 305ci
Transmission: TKO600
Axle/Gears: 9 bolt
Bilstein "HD" shocks and struts that Spohn sells... Or another model?
Old Jan 19, 2004 | 04:58 AM
Kandied91z's Avatar
depends on the spring selection the hd's are perfect for a pro-kit height. check elsewhere though as you can find them cheaper....
Old Jan 21, 2004 | 06:08 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
KYB's are a good replacement for the $$ minded person.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
