Front Brake Calipers
Old Jan 14, 2004 | 06:26 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Anyone ever heard of FENCO for reman calipers??? I'm thinking of getting a pair for the front.
I am getting a lot of grinding when the brakes are applied. No pulling or dragging.. just a real hefty grind . At a glance the ouside of the rotor is smooth and shiny, but have yet to look at the other side of them. Based on a few threads I have read, the calipers would be the most likey problem right. The calipers look like OEM stuff. I just had the a few months so I don't know the real history of maintenence(SP?). Does this sound reasonable solution to the problem?? THe Fenco reman parts are dirt cheap.. so if they are respectable parts, I just my go with them. Ideas??
Old Jan 14, 2004 | 09:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yep, that's what my 1LE calipers are. They're fine and economical.
Ed
Old Jan 15, 2004 | 04:46 PM
hitman's Avatar
color
Anybody know if these parts can be powdercoated without having to dis-assemble the caliper?
Old Jan 15, 2004 | 06:00 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Grinding!
I'm almost certain thats the pads worn down to the metal.Done it loads of times in some of the old piles of crap I've had.
Old Jan 15, 2004 | 06:59 PM
hitman's Avatar
erictheviking
Thanks for the tip.. I should investigate a bit further on the inside of the brake set up before spending time and money.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
