Willwood Valve Mod
Old Jan 24, 2004 | 10:43 AM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
Willwood Valve Mod
Performed the willwood prop valve mod that was outlined in tech article. Worked excellent. Went from erratic 2000 to 2300 RPM launch to 3000 RPM consistently. was not really difficult. Must be very carefull w/flares. All 5 flares worked good with Summit tool. The only leaks I had was from not tightening enough due to surgery on right hand. A BIG pair of pliers and a pipe on wrench corrected this. Bleeding was a pain but ultimately worked. I suspect too many up and down lines from line lock made bleeding difficult. A power bleeder would have helped.
Since this is a drag only car, bias for street driving is not an issue. The rears will lock before fronts if you hammer brakes, at least on grass. On pavement, fat slicks and skinny fronts help alleviate this.
Congratulations/Thanks to Robb Millet who researched and wrote article.
Old Jan 24, 2004 | 11:01 PM
25THRSS's Avatar
I plan on doing this too. I just wish there was a way you could keep your stock prop valve so that the brake light will still work. Oh well.
Old Jan 26, 2004 | 02:33 PM
Pat Hall's Avatar
I just got my wilwood valve the other day and I printed off a copy of Rob's article. Very informative piece.
db057
Apr 28, 2019 07:45 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
