Does anyone have or make 9bolt caliper brackets for PBR's
Old Jan 24, 2004 | 10:32 PM
semiller26's Avatar
Car: 1986 Trans Am
Just as the topic says. I have a 9 bolt and want the PBR disc brakes instead of the Delco ones I have. I need of course the mounting brackets for the calipers. I heard these are hard to find. I noticed Resource has brackets but they look to be 10 bolt. Is anyone fabing these? Could I convince someone to make me a pair?
Old Jan 24, 2004 | 11:58 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I have a set, dont really wanna let em go though
Old Jan 25, 2004 | 12:44 AM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
ebmiller
he has what you need
Old Jan 25, 2004 | 09:57 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
How much are they?
Old Jan 25, 2004 | 02:17 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Are you referring to the bracket the caliper actually sits in or the backing plate that the bracket and caliper bolt too? The caliper brackets(cradles) are still available from GM(mine cost $75 for the pair). I have two spare sets,one new and one used. I also have a set of backing plates with dust shields in tact for a 9 bolt but I plan on holding on to them. The cradles are interchangeable from 9 and 10 bolt rears.
Old Jan 25, 2004 | 03:27 PM
semiller26's Avatar
Car: 1986 Trans Am
No I was refering to the brackets that need to be bolted to the axle to attach the PBR setup.
Old Jan 25, 2004 | 03:29 PM
semiller26's Avatar
Car: 1986 Trans Am
Oh by the way can new PBR calipers and rotors be obtained from GMpartsdirect does anyone have the part numbers for these I would prefer new ones as opposed to used ones.
Old Jan 25, 2004 | 04:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just so that you can weigh all your options, note the following CarQuest prices:
Rotors: BDR 55022 $54 per (in my little burg anyway).
Remfg Calipers: Cal 18-4346 and 18-4345 $82 per
Loaded: Cal 16-4346 and 16-4345 $99 per
There are probably cheaper prices out there, if you do some digging.
I mention the above only because I think you'll be shocked/horrified at the prices without a core--at least I was. CarQuest's price was $176 per for the unloaded. That being so, GM may take your first born! GMpartsdirect has wonderful prices, but if you've purchased from them before, you know that shipping and handling can be outrageous. Anyway, food for thought.
I have a pair of nine-bolt disc backing plates, but I haven't decided what to do with them (I'm doing PBR brakes on a ten-bolt and I've already purchased the ten-bolt backing plates, so in reality I really don't need them).
JamesC
Old Jan 25, 2004 | 04:37 PM
Mongoose's Avatar
Car: 90 Formula
Check this site out. I just ordered a set of Raybestos PG OEM quality rotors for $13.91 each.
www.rockauto.com
As for PBR calipers,I wound up paying right at $200 for my pair of loaded calipers from Advance Auto and that's with cores I found through the classifieds page here. Unfortunately they don't come with the brackets and springs for the park brake cables.
Old Jan 25, 2004 | 05:00 PM
JamesC's Avatar
More food for thought:
http://www.tacreationsusa.com/suspensi.htm
JamesC
Old Jan 25, 2004 | 08:10 PM
semiller26's Avatar
Car: 1986 Trans Am
$13.91 for a rotor now that's what I like to see. at that price I'll pick up fronts so I can have hubs made for the C5 upgrade.
Old Jan 25, 2004 | 08:50 PM
semiller26's Avatar
Car: 1986 Trans Am
I just bought two rear rotors from rock. Good price but the shipping was as much as the rotors. Good website though very comprehensive.
Old Jan 25, 2004 | 09:04 PM
semiller26's Avatar
Car: 1986 Trans Am
I'm thinking I will just get the calipers from Third Gen Resource and clean them up. I will call them in the morning but until then does anyone know if these come with the carrier and pins ?
Old Jan 26, 2004 | 02:28 PM
Pat Hall's Avatar
As far as the backing plates go, if you find yourself in a pinch, you can modify the ten bolt pbr plates to work on your nine bolt. All it requires is routering out the holes a bit to line up with the nine bolt axle flange holes. We did this on my buddy's iroc. He had a grenaded ten bolt with the pbr brakes and a good nine bolt disc rear that was missing the backing plates. He was too broke to afford to buy the correct backing plates, so we modified the ten bolt ones and it worked out just fine.
Old Jan 26, 2004 | 02:43 PM
semiller26's Avatar
Car: 1986 Trans Am
Good to know I was wondering if that might work. Rock Auto called this morning. It happens that they are out of stock and don't have any of those $13 rotors for me but were happy to sell me the $40 ones that they did have. And didn't know when they would be getting any of them in. To good to be true? Looks that way.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
red90IROCls1
Aug 25, 2015 06:56 AM
