Howe calipers
Old Jan 27, 2004 | 07:54 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Howe calipers
I have an 89 IROC with rear end out of a 91--4 wheel disc brakes.
I was told that these Howe "metric" calipers would fit (direct bolt-on) front and rear, as long as I was willing to give up the parking brake (which I would if it is an improvemant over OEM).
http://www.howeracing.com/Braking/In...ton-Metric.htm
Does anybody know if they will fit?
They have 2.625 or 2.75 pistons--anybody know what the OEM piston sizes are on the front Delco's and the rear PBR's?
Old Jan 27, 2004 | 05:27 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
ANYBODY?
Can anybody just tell me if the caliper that is referred to as the "Metric caliper" is what fits the front of an 89 IROC?
Old Jan 28, 2004 | 08:50 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Old Jan 28, 2004 | 10:39 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
http://secureperformanceorder.com/us...ProductID=5192
I found these calipers a while back. There might be some issues with pedal travel with the original master cylinder. Either way an adjustable proportioning valve for the rear end would be recomended.
Old Jan 28, 2004 | 11:33 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Howe calipers
They will work fine on the front. Don't know who told you that " You would have to give up your parking brake "....as these are front calipers only. Haven't seen any of our cars with Park brakes on the front.... Obviously a salesman you were talking to. They wil definately NOT bolt onto the rear. In any shape or fashion.
Do replace the stock proportioning valve with an adjustable unit though. The back PBR's do need to do more work. You might notice a slight increase in pedal travel...but the Master Cylinder should have more than enough capacity to handle this slight increase in cylinder volume. The larger pistons will definately increase clamping force.
Pad choice makes a differnce as well. I've had very good success with the Bendix Titanium line.
Old Jan 30, 2004 | 06:21 PM
WS6 Berlinetta's Avatar
Has anyone looked at the dual piston calipers from how they look like they should bolt right up but I'm not sure if they are metric or not and how much that really affect the install.
R
Old Feb 2, 2004 | 05:23 PM
chevy8ford's Avatar
Car: 88 Firebird
I just bought a set of these from Summit along with some powerstop drilled rotors. I have yet to put them on, but when mocking them up i realized that my earl's hyperfirm brake lines would not fit out of hte box due to their large rectangular (instead of factory style rounded) banjo end. Busted out the grinder and cured that by rounding off the corners. Also US Brake warns you that with the larger piston you may need their fitting, however they do allow the stock bolt to go in up to .380". I measured the stock bolt and determined that there was less than that, but still not feeling comfortable, i decided to use compressed air to pop out the piston. Did a visual check and the bolt is NOWHERE NEar coming into contact with the piston. Don't know what they were smoking when they wrote that warning?
Anyway after i get them on and test them out, I will post here again. Since i needed new calipers anyway, i decided that 79.00 wasn't a bad price for a stock looking improvement.
Any other experiences?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
