Odd drivetrain "pop" while downshifting
Old Jan 28, 2004 | 02:53 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Well fellas, heres the situation. If I am coasting to a stop while the car is in 3rd, or D (this is an A4), when the car slows down and the tranny automatically kicks it into second, I hear this POP under the shifter assembly. Only in this setup. If the car is in OD under the same conditions, it will not do this. The same goes for 2nd gear, of course. What gives. Its not the tranny mount, replaced it with a poly mount a few months ago. Might it be the torque arm bushing? I'm planning alota susp. mods this year, would a good non adj torque arm be worth it? I have heard of several different models. One that actually relocated the mounting point off to the underside of the car. Is this a hard install, I know some welding has to be involved. Anyways, thanks fellas
Will
Old Jan 29, 2004 | 08:28 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
It could really only be a couple of things that I can think of...
1. The torque arm rubber or mount is deteriorated
2. The exhaust mounting brace for the cat is deteriorated (or not there if you have a custom set up).
3. Engine mounts are worn, allowing the entire engine/trans to twist to far, causing contact.
Old Feb 5, 2004 | 02:37 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Tranny mount ripped in half makes that sound too.
Old Feb 5, 2004 | 10:38 PM
norcalz28's Avatar
Yeah its a fresh poly mount, thats not it.Still trying to figure it out. Guess this and alot of other problems will have to be fora few months. Till I can purchase the remaining parts to do the major mods
Will
Old Feb 10, 2004 | 11:32 AM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
you know what.i had this problem with another GM i had.did it only slowing for toll booths and stuff.Turns out i had a posi rear and never put in the additive i was supposed to.put it in and it was fine.mabye this will help you
Mark_ZZ3
May 24, 2018 01:02 PM
tyeo098
Nov 30, 2015 06:27 PM
Chevykid810
Sep 28, 2015 12:57 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
