Blue Lowering Springs??
Old Dec 13, 2003 | 12:17 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Hi folks! I bought a used set of springs off of the classifieds. the seller said they were eibachs. when i got them they were blue. I called eibach and they said"not ours". i have then on the car, it is very low in the front. the springs are very very stiff. who makes these?
Old Dec 13, 2003 | 02:24 PM
MdFormula350's Avatar
i have blue ones from eibach they are their drag launch kit, not really lowering springs. just wanted to put that in the air.
Old Dec 14, 2003 | 01:44 PM
these are definatly NOT drag springs. the car is low and stiff, just look-
Old Dec 14, 2003 | 01:56 PM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
They might be hotckiss lowering springs
Old Dec 14, 2003 | 04:05 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
hotckis are grey.......
they maybe BBK ? theirs are blue.
i didn't think they make a spring for our car though.....
Old Dec 14, 2003 | 05:19 PM
hummm......... they are a bright sky blue. they are definatly for a camaro. anybody else ???
Old Dec 14, 2003 | 05:28 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Suspension Spring specialists have blue springs.
And our springs are a very very common size. Especially in the racing world.
Old Dec 16, 2003 | 03:16 AM
CRace46's Avatar
yep The color fades a little over the years- And I think they are using a little darker blue paint nowadays.
Old Feb 9, 2004 | 06:35 PM
bump...
Old Feb 9, 2004 | 06:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yea those are not Eibachs and that does look a bit low. I would say you are going to have to buy some different springs. Or I would try to contact the owner of the springs and see if you can return them.
Old Feb 10, 2004 | 10:05 AM
Graboid's Avatar
in my opinion it is has a good stance, the back might even go down another 1/2 inch
Old Feb 10, 2004 | 10:08 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The front shouldn't be that low if the car is just sitting there. I think that the rear is perfect but you are going to have rubbing problems as those springs get older and sag a bit. Not to mention that the tires will start to creep up into your fender well and just look kinda silly.
Old Feb 10, 2004 | 11:39 AM
I don't think they will ever sag. they have been in for a year. The front is too low. the spring spacers I am talking about are not those cheesy j.c. whitney rubber inserts. they are machined aluminum disks that fit in the spring perch. alvail. in different heights. just saw them in a story in chevy high performance from a year ago. will try to scan it.
Old Feb 10, 2004 | 11:52 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Ok, I understand now. Yea a spring pearch would work and allow the spring to work how it is supposed to. I thought you wanted the nascar style rubber wedge in between the coils. Believe it or not any srping will sag over time. Yours are only a year old but 3 or 4 years from now, or less depending on how you drive, I bet you will be even more un-happy.
morrow
Jan 13, 2024 12:29 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Night rider327
Sep 2, 2015 04:17 AM
