How to correctly check the offset of your wheels?
Old Jan 31, 2004 | 07:57 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Anyone know where to measure? I get confused between offset and backspace.
Old Jan 31, 2004 | 09:49 PM
Bandit5's Avatar
If you know your backspace, you can figure out your offset easily.
Just measure the width of the wheel and divide that by 2. Now, take that number, and subtract your backspacing. That should give you your offset.
Basically, the offset is the distance between the center of the wheel and the hub mounting surface. Once you know that, you should be able to figure out how to measure it. Long guidline short: after you measure the width, just use a straight edge on the back of thew wheel and measure.
Fronzizzle
Mar 18, 2019 08:29 PM
IroczFan
Oct 6, 2015 10:13 AM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
