Wheel Mods?
Old Feb 1, 2004 | 05:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Wheel Mods?
My dad was telling me about some of the things that he had done to his Z28 ('73) when he had the car, but one thing he was telling me really caught my attention because I've never heard of it being doe before.
On his Camaro, he had a set of Cragar S/S wheels. What he told me was that he had brought the wheels into some shop, and they actually widened the wheels by welding 2" to the inside of the two rear rims and 1" to the inside of each front rim.
I was just wondering, are there any places that still do this sort of thing? And can this be done to cast aluminum wheels?
Old Feb 1, 2004 | 05:58 PM
85TransAm406's Avatar
Car: 1985 Trans Am
yes, it is still done, but i've only seen it done to steel wheels. I don't know about aluminum wheels, though.
Old Feb 1, 2004 | 07:16 PM
JERRYWHO's Avatar
Re: Wheel Mods?
Yes, I did my wheels at home. The rears are now 9 3/4 wide.
Jerry
Old Feb 1, 2004 | 07:17 PM
JERRYWHO's Avatar
One more picture of the rears done with only one weld.
Old Feb 1, 2004 | 07:20 PM
JERRYWHO's Avatar
Now the next cool thing to do is cut the fronts down to 6 inch and run 205 front tires on your drag car. It's sure fun to go to the track with stock wheels and run mid 11s.
Jerry
Old Feb 1, 2004 | 07:26 PM
Car: 1985 Trans Am
Spiffy!
Did you just use another set of wheels to make the wider wheels?
Old Feb 1, 2004 | 07:37 PM
JERRYWHO's Avatar
Originally posted by 85TransAm406
Spiffy!
Only one set of four. All you do is cut the front wheels on center and then cut the rear 2 inch offset to the inside and you just swap the rear part of the wheels and you get 6" fronts and 9.75" rear wheels.
Jerry
Old Feb 1, 2004 | 10:18 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Jerry
That's a frucking awesome idea. Very nice!
Tim
Old Feb 2, 2004 | 11:44 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Ok, if I paid for shipping both ways, how much would you charge to do this for me??? !!!
BADA$$ !!
Old Feb 2, 2004 | 12:41 PM
laiky's Avatar
I think thats one of the most original ideas i have seen on this bored!! great job, very trick!
Old Feb 6, 2004 | 10:05 AM
JERRYWHO's Avatar
BADA$$ !!
1bad91Z
Right now I only do things for fun, trade or to see if it can be done.
Here in so-cal a couple of shops do them every day. ( one that I go to allways has 100 or more in house at any time.) You will find eveyone gets $135 per wheel or $500 a set.
Jerry
Old Feb 22, 2004 | 08:02 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Jerry,
What are you using to cut the wheels? That seems like it would be the hardest part Do they balance out on a tire machine easily?
Thanks for the info.
Kory
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
