Z28 brakes
Old Feb 3, 2004 | 11:11 AM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
Z28 brakes
Are the front callipers different in a 91 z28 than the ones on a RS. I have switched rear ends and porportioning valves, but dont know if the front breakes will work because the car has RS front callipers. Thanks
Old Feb 3, 2004 | 01:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's no difference in front brakes on any model unless you have options 1LE or B4C.
Old Feb 3, 2004 | 03:47 PM
ar_mcadams's Avatar
Car: 91 camaro
Ok, so the 91 and 92 Z28s with rear disk had the same front breaks and then RS, unless the they had the performance package? Is the front callipers with the two small pistons in them the ILE brakes?
Old Feb 3, 2004 | 04:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All cars without performance brake packages had the same single piston cast iron front brakes, regardless of year or rear brake options. The 1LE fronts are aluminum with two pistons.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
