Possible to use 4thgen spindles????
Car: Faster
Engine: Than
Transmission: You!
Is it possible to use the whole 4thgen spindle, that way I can run 4thgen wheels with-out having to use a spacer?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Possible to use 4thgen spindles????
Car: 1992 RS
Engine: 406 Stealth Ram
Negativo. Unless you wanna rig up the upper a-arms, steering linkage and all that jazz, just get some spacers for the front from Skulte and use a 4th gen sized rear end. Or you could swap front clips with a 4th gen and hang 3rd gen fenders and nose on it, like Fatal88
Car: Faster
Engine: Than
Transmission: You!
Yea, that would be the shizzle! Oh well, it was worth a try! I guess I will have to use a front spacer after all.
Hmmm...... unless I can find a complete 4thgen front subframe......
Car: Faster
Engine: Than
Transmission: You!
Could I get awat with just using the 4thgen engine cradle / spindles / a-arm's / and coil over setup?
Or, would I have to use the whole subframe?
Can this be done while still retaining the 3rd gen strut towers?
Car: '90 RS
Engine: 377 LSX
Car: 1992 RS
1992rs/ss
16
Jan 28, 2016 09:58 PM
rb85TA
26
Sep 14, 2015 10:29 PM
