converting to manual brakes
Old Feb 16, 2004 | 05:50 PM
iroczguy's Avatar
what would it take to converter my iroc to manual brakes, curious cause my carb/intake setup dont have vaccuum ports..
thanks,
Greg
Old Feb 16, 2004 | 07:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Why on earth would you want to do that? These cars are already hard to stop as it is and taking the power brakes away would make it even harder.
I have 2 suggestions: Install a vacuum pump and hook up the brakes to that, or just drill and tap a vacuum port on the manifold, not that hard. A good spot is right behind the carb location or on one of the intake runners.
No offense, just thinking safety here. Good luck!
Ed
Old Feb 17, 2004 | 05:53 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Just to throw some gas on the fire.... I was thinking of converting to a dual master cylinder setup with a balance bar. Something like you would see in a road course car. I think it would clean up the engine compartment a little and be more adjustable than a rear proportioning valve. I don't have any issues with low or non existent vacuum. The fabrication to make that work is what I don’t like, but a single master cylinder that is properly sized should be able to work. But ebmiller88 is right, it can take more pedal effort.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
