Supposed to be loose???
Old Feb 20, 2004 | 12:51 PM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
I don't know what these pieces are called but they're both connected to the lower sway bar, and each one is loose, meaning they'll easily giggle back and forth when i wiggle them with my hand. should i tighten these up or are they supposed to be loose?
Old Feb 20, 2004 | 01:04 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
No, they shouldn't be loose...Tighten them up. Check both sides, front and rear just to be safe.
Old Feb 20, 2004 | 01:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THose are called "end links".
THey're supposed to be tight.
If they have got loose by themselves, they're worn out. Go to Auto Zone and you'll find them hanging on a card in an aisle, for about $15. Replace them. You'll be amazed at the difference new ones make.
If you really want to shock yourself, get a set of rear springs (Moog CC635 or equivalent) and rear shocks, and the end links, and a pair of sway bar bushings all at the same time; and spend an hour (or 2 if you're real leisurely about it) and totally renew your rear suspension. You won't recognize your own car the frst time you drive it.
Old Feb 20, 2004 | 02:12 PM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
Yup...RB is right..Auto Zone stocks the Polyurethane end link kits...Pick one up and throw 'em on...then tighten them up real good!!
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
KO1
16
Oct 15, 2015 05:00 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
