sway bars
Old Feb 24, 2004 | 06:36 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
sway bars
anyone know if 4th gen 1 le sway bars will fit on my 89 formula or are the ws6 sway bars just as good?
Old Feb 24, 2004 | 08:10 AM
MdFormula350's Avatar
ws6 bars are pretty good i mean they are usually 36mm front and 24 mm rear.
these would look to be an improvement over the ws6's
http://www.spohn.net/product.cfm?productid=1311
Old Feb 24, 2004 | 08:15 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
MD Formula you didn't answer my post at all do you read what your responding to or just post for the hell of it
Old Feb 24, 2004 | 08:22 AM
i did say that the ws6 sway bars are good enough, they are the biggest ones offered on thirdgens, i have no clue about 1LE 4th gen sway bars and i doubt they are bigger than 36 / 24.
i just put down a link to show bolt in kits for thirdgens that would be better than ws6 bars.
geez.
https://www.thirdgen.org/techbb2/sho...+gen+sway+bars
and i at least took the time and responded to ur other post about the shocks and struts.
slow ur roll
i have helped loads of people one way or the other.
Old Feb 24, 2004 | 09:34 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If I understood my few readings, the rear bar is swapable, but front is not.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
