Can I use a 4th gen 36mm sway bar on a 3rd gen car?
Old Mar 8, 2004 | 09:16 PM
FrigginA's Avatar
Can I use the 4th gen 36mm sway bar on a third gen suspension?
Old Mar 8, 2004 | 09:41 PM
FrigginA's Avatar
I think the answer is no.
I did a search under interchange and the most comon answer was ,the front no, the rear yes.
I needed an answer fast so I posted because I didn't know if I would find the answer :rockon:
Old Mar 8, 2004 | 10:32 PM
MdFormula350's Avatar
i am pretty sure its still no for the front and yes for the rear.
Old Mar 8, 2004 | 11:18 PM
bes217's Avatar
mdformula, has it spot on.
Old Mar 9, 2004 | 12:42 AM
3rdGenBlackBird's Avatar
Did 4th gens ever get a better rear sway bar than 3rd gens?
Old Mar 9, 2004 | 12:48 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Nothing from the front suspension on a fourth gen will interchange, except maybe the swaybar endlinks They use a completely different coilover setup and hubbed rotors. Fourth gen brakes can be made to fit, but its nowhere near a direct swap.
Old Mar 9, 2004 | 01:17 AM
vjo90RS8's Avatar
Car: 2002 Z28
i think the biggest 4th gen sway bar is the 1LE 32mm one, i could be wrong but thats all i remember seeing
Old Mar 9, 2004 | 09:18 AM
bes217's Avatar
Because of how they have a coilover suspension and different things like that they didn't need as big of a sway bar.
Old Mar 10, 2004 | 08:52 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
The 32mm bar is the largest 4th gens came with but I suspect the fact that 32mm is the largest has nothing to do with the fact they have a different suspension setup and more to do with the extra power and speed the cars are capable of. For a street driven car on street tires with the avg everyday driver a smaller bar is better suited.
Old Mar 11, 2004 | 04:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What size rear bar to 4thgens have? I need to find a 24mm rear bar for my '83, and prolly wont have much luck looking in 3rdgens for one.
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
AkDrifted
Aug 17, 2015 07:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
