Guys with 9.5 rims, what bs do i need?
Old Mar 14, 2004 | 09:20 PM
nolanr0413's Avatar
Car: Trans am
i plan on getting 17x9.5 all around. I know the rear bs is 5.5 but what shoulg i get for the front.I have an 85 so i dont have the 1le brakes. Chevy ken has 5.25 and he says that is perfect and that 5.5 would hit.I dont care if i cant switch rims front to back . But i want the rims to be perfect . THey are boyd coddington so i can get any bs i want. thanks guys , i need some help. thanks jeff.
Old Mar 14, 2004 | 09:58 PM
CrazyHawaiian's Avatar
Car: too many ...
I'd go with what ChevyKen said. I dont have any experience with 9.5" wide in the front, so I cant really say. If you really want to know the perfect BS (as in does not rub/hit at full lock, and has the side fender/rim profile you want), check out Skulte's website. Using some cardboard, you can pretty much simulate any BS measurements and see what the final product will look like. I always thought it was 5.5" fronts (alot of guys with 17x9.5 TTII on the front run 5.5" but then also complain about contact with the tie rod ends), but ChevyKen said 5.25" was better with his Boyds with no contact, so I'd go with that.
Old Mar 15, 2004 | 03:22 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I have 8,5x17 et 13 wheels at my z(-85).they have 133mm backspace and that is almost max if you dont want hit to tie rod ends.
Jari
Old Mar 15, 2004 | 02:27 PM
nolanr0413's Avatar
Car: Trans am
ttt
Old Mar 15, 2004 | 05:59 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i got 10'' wide rims and i used a 5.5 backspacing
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Exxon Limited
Aug 9, 2015 08:13 PM
