Can one knotch the a-arm nub
Old Mar 20, 2004 | 03:19 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Can one notch the a-arm nub
that sticks out in the engine bay?
here's the delima:
Shot 1
Shot 2
These are the tubular eahaust manifolds off of a 2000 F-body 3800 car. It rests on the support, but I'm also thinking about the exhaust pipe, cornering, and just the normal engine vibration from idling/running.
Car will not see any autocross but will be my daily driver.
Thanks in advance.
Old Mar 20, 2004 | 04:47 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I took off the bulk of my perches, they made the big block headers too close so I cut a slit up the middle, heated the metal and rolled the two sides closer together, got about an inch of useless metal outta there. Took less than an hour for each one. I`m not understanding why your putting a 3800 engine in though
Old Mar 20, 2004 | 08:30 AM
Engine: 5.7 / 7.4
3800 inthere due to 3.4 catching fire & toasting the harness.
Plus, I got the 3800, tranny, pcm & harness for $200.
Old Mar 20, 2004 | 04:25 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
Go ahead and notch the control arm bracket. Just add more metal on the opposite side where the exhaust doesnt go. Are you kidding me? its well worth it for $200 for a 3800 4th gen engine and tranny. You definately didn't go wrong there!. PSST! you'll easily hang with most 305TPIs. Get some pistons and a crank from a fwd l67 and Slap on the supercharger. That'll make some v8 boys get really jealous hehehe. I'm sure you'll enjoy your 3800 engine. Good luck
Old Mar 20, 2004 | 07:11 PM
Engine: 5.7 / 7.4
Thanks. THat's the fomula for fitment probs on using the GTP motors in the 3rd & 4th gen car, the TB ending up in the dash. There are turbo kits & powerdyne kits for the 3800's, but that's for a different forum . And yeah, going from 135hp & 160tq, then 160hp & 200tq to 200hp & 225tq is a nice step up
But when I bought my tires, I wasn't planning on the 3800 swap w/more power
edit: pic of what was cut
gta892000
Aug 11, 2019 11:16 AM
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
92projectcamaro
Sep 24, 2015 08:09 AM
gta892000
Sep 16, 2015 12:37 AM
