C5 front rotor offset? (paging toddlsf)
Old Mar 20, 2004 | 09:00 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
Would anyone happen to know the exact offset of a C5 front rotor? (Distance from the inboard face of the disc to the inboard face of the surface that sits against the hub)
Also, what is the exact diameter of the rotor? Is is 12.6" or 13"?
Thanks,
Tom
Old Mar 21, 2004 | 06:58 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
"I have no idea on the offset, but it's a true 13" rotor."
EDIT: I'm wrong, sorry.
Ed
Old Mar 21, 2004 | 01:33 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Thanks Ed.
Maybe someone will chime in with the offset. If the offset is withing my usable range I may be using C5 rotors with my front Wilwood caliper setup. C5 rotors are slightly cheaper and easier to get then a two piece rotor. Especially if the C5 rotors are lightly used.
Tom
Old Mar 21, 2004 | 02:12 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Ed
I thought the C5 rotor was 12.75"? I know the HD C4 rotors are bigger. Theres a comparo on corvetteforum.
Old Mar 21, 2004 | 02:20 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Justin,
Do you have a link to that comparison on the corvette forum? I couldn't find it.
Tom
Old Mar 21, 2004 | 02:26 PM
Originally posted by Colt
Justin,
Tom
I guess I didnt bookmark the forum page, but i got the link off corvetteforum for the writeup.
http://www.superchevyperformance.com/misc/c5brakes.asp
Here's a good comparo for C4 calipers
http://www.superchevyperformance.com...4calipers.html
Old Mar 21, 2004 | 02:32 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Thanks Justin.
Too bad they didn't list an exact diameter or offset on that page. I'm looking for someone who can mic the dimensions so they can be pretty close to exact. I need to know them so I can set my caliper distances.
Tom
Old Mar 21, 2004 | 04:32 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I just measured my PowerSlot C5 rotors that I have sitting here until the rest of my parts get in. The diameter is 12.75" and the offset is 1.5" Let me know if you need any other dimensions.
Old Mar 22, 2004 | 01:05 AM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Steve, thanks for the measurements. You're absolutely sure the 1.5" offset is the same distance as in the picture below??
If that's the case then that means the built in hat has a .250" offset. Wow, that is small.
Tom
Old Mar 29, 2004 | 09:45 AM
toddlsf's Avatar
Yep, the distance in your picture is 1.5 inches. Sorry that I didn't see this post earlier. I went on vacation for about a week and a half and am now just catching up. FYI, you can get the C5 rotors really cheap at NAPA. I think they are only like $20 - $25.
Todd
Old Mar 31, 2004 | 06:27 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Hey guys,
I have just bought the calipers and rotors from NAPA $23ea ( man thats so cheap I can nery beliv it ) off ebay to do this swap and have heard conflicting opinions on the thickness of steel required for the adapter plates. Did you use 1/2" or 5/8"? Thanks
Old Mar 31, 2004 | 07:29 PM
toddlsf's Avatar
My brackets are half inch.
Old Mar 31, 2004 | 09:25 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Thank you very much!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
