87 drum to a 88 disk
Old Mar 21, 2004 | 09:21 PM
l98irocz's Avatar
i have a 87 iroc and my rear end just went out.
i have a disk rear end out of a 88 iroc. it is out of a manual 305. it has the g92 option. it is a 3.45 gear. what will i need to grab of the 88 to make it work on my 87. (master cylinder, e-brake cable)?
thanks
mike
Old Mar 22, 2004 | 07:21 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hi Mike...where ya been?
Since it's a drum to start you'll need the e-brake cables but that's about it. I don't think I'd worry about the prop valve any, and definitely not the master. I'd probably swap to PBR rear brakes though.
Ed
Old Mar 22, 2004 | 07:50 AM
l98irocz's Avatar
ed
its been a while.. well i've had to lay low on the car for a while because my girlfriend and i are having a baby.. i am kind of limited on my options ... i got the rear end for a $100 from brian... he's getting a 88 iroc for spair parts.... but thats all ill need is the e brake cable?... do you think that i should go buy that new one because of the recall?... will i need to go and get a new speedo gear as well... thanks ed
mike
Old Mar 22, 2004 | 12:27 PM
ebmiller88's Avatar
Congrats on the new arrival, we're expecting too.
You'll have to put up with those old calipers unless you do the recall kit install which isn't too hard, just a caliper rebuild. Just pull the e-brake cables along with the rear if you can, they will work with that rear. And yes, I forgot about the speedo gear swap. You'll have to do that to get the speedo to read right.
$100 for a 3.45 9 bolt...nice find!
Ed
Old Mar 22, 2004 | 01:24 PM
l98irocz's Avatar
thanks ed .. congrats to you as well .. for now i guess ill just deal with it... thanks for all your help on this.. we should get together sometime... brian, chris , you and i... talk to you later
6speedIROC
16
Mar 15, 2023 08:33 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
dbrochard
Sep 25, 2015 04:56 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
