One brace supposed to be on each side?
Old Mar 25, 2004 | 10:26 PM
25THRSS's Avatar
I have a 1992 Camaro RS was has been in an accident before, and a few nuts and bolts are missing here and there, but I was under my car a couple days ago and noticed one brace on the drivers side and none on the passenger side where it looked like it should be. I'm not sure of the exact name of the part, but all I can say is it bolts to the frame where the wonderbar goes and connects to part of the fender. It looks like the brace pictured on the bottom of this pic. Should there be one on each side?
https://www.thirdgen.org/techbb2/sho...ghlight=braces
Old Mar 25, 2004 | 11:25 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Yeah there should be one on each side, held in by 2 bolts on the k-member side and one on the other.
Old Mar 26, 2004 | 12:46 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I've only seen that bottom brace on the drivers' side. It braces the area of the front rails behind the steering box, up to the bottom of the battery tray.
Old Mar 26, 2004 | 02:45 PM
Orinackra's Avatar
Trust me, theres one on each side in the same spot. I did a k-member swap 3 weeks ago, and there is definitely 2 of em.
Old Mar 26, 2004 | 03:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I've gottem on both sides.
2 horizontals from frame horns, to crossmember
**CORRECTION**
1 verticals from frame sides, to bottom of the battery tray areas.
I only have ONE of the braces your talking, it is on the side with the battery.
Old Mar 26, 2004 | 03:09 PM
25THRSS's Avatar
the one I'm talking about is not attached to the k member
Old Mar 26, 2004 | 03:37 PM
Orinackra's Avatar
Oh ok, I know which one you mean. I'll go look later on today when I get a min.
Old Mar 26, 2004 | 03:41 PM
25THRSS's Avatar
thanks, I appreciate it
Old Mar 26, 2004 | 03:54 PM
91Z28-350's Avatar
I have 3 on my Z28 also. Similar to Dale's setup, except that on my end for the 3rd piece, it is on the driver's side and not the passenger's. The other 2 pieces go from frame to k-member. The 3rd piece doesn't make any sense where it is and am wondering if I should move it under the battery, or just add a 4th.
Old Mar 26, 2004 | 10:19 PM
Orinackra's Avatar
Took a look, and yeah, theres only one on the drivers side.
I guess I jumped the gun cause I saw those 2 braces on the end in that pic and those are the ones going to the k-member. The middle one in the pic is the one thats on the driver side. Hopefully that clears up the confusion.
Old Mar 27, 2004 | 12:21 AM
I wasn't confused
Old Mar 27, 2004 | 12:15 PM
Orinackra's Avatar
Originally posted by Petes 84Z28
I wasn't confused
Never doubted you for a second!
Old Mar 27, 2004 | 07:28 PM
25THRSS's Avatar
Hey thanks for checking man. Atleast I don't have to worry about that anymore. Why only on one side though, it doesn't make sense.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Fronzizzle
Aug 17, 2015 02:52 PM
sonu1975
Aug 11, 2015 08:38 AM
novaderrik
Aug 10, 2015 12:44 PM
NBrehm
Aug 5, 2015 07:57 PM
