Rear swaybar bushing?
Old Apr 3, 2004 | 09:09 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have the FE2 code and from that it says tht I have the 24mm swaybar in the rear...what would happen if I put 22mm bushing on the rear?
IS the bushing suppose to be tight around the bar or loose? I went to AZ and got the 22mm bushing and already put them on without checking in here first to see what size I have.
Once I tighten the bolts down the bushing closed up completely around the bar...so am I ok?
Old Apr 3, 2004 | 09:59 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
should be. might have a little play in them. id tighten the hell out of it. or better yet, buy new ones. they are cheap and easy to install
Old Apr 3, 2004 | 10:12 PM
THe bushings that I put on are for 22mm or 7/8" swaybars and I did the cresent wrench thingy and measured my rear bar and it came out to 7/8" so I guess Im good to go!....and then I was reading that the slits go towards the front and luckly I did that without knowing that they were suppose to be that way.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
