How many bolts hold steering box?
Old Apr 13, 2004 | 04:29 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
How many bolts hold in the steering box? the reason I ask is becasue I think mine is loose.. when I turn the wheel lock to lock I get a nice thunk sound from that area, when i pry against the box and turn the wheel the sound goes away, it doesn't look visably loose and all the bolts appear to be there and not broken, so first I will try to tighten it up, if that doesnt work I'll be replacing it..
Old Apr 13, 2004 | 05:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is this what you are looking for?
Old Apr 13, 2004 | 08:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Likely, the frame is cracked around the bolts somehow, as usual.
Weld a reinforcement plate in inside the frame; and get yourself a "wonder bar".
Old Apr 13, 2004 | 10:10 PM
89RsPower!'s Avatar
already have one from spohn.. don't see any visable damager either..
Old Apr 13, 2004 | 10:21 PM
89RsPower!'s Avatar
gonna remove the box for a further inspection...
Old Apr 15, 2004 | 12:10 PM
CaysE's Avatar
It's possible that the sheet metal that the box is mounted to could be damaged, but I would think it's more likely a ball joint or tie rod that needs replacing. Have you rebuilt the front-end?
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
johanlindgren
Aug 16, 2015 12:16 AM
