Alignment Question
Old Apr 14, 2004 | 04:24 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
New suspension. Alignment question.
Alright i've spent the passed 30 min looking up some alignment specs because i've spent the last few days putting on all my new suspension. I've gotten a pretty good general idea of about where it should be but i was wondering if anyone out there would give me some suggestions that would work best for my setup. All my mods that are going on are in my sig below. I am looking for a high performance street setting. Thanks a lot for any input here.
Old Apr 14, 2004 | 08:43 PM
5.0Camaro's Avatar
come on anyone????????????
Old Apr 15, 2004 | 06:01 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
You kinda answered your own question. I assume you've seen :
Code:
                     Caster           Camber          Toe Total
                      (deg)            (deg)            (in)
                     L      R         L        R
   Normal Street +4    +4.5       -.5      -.5        3/32
   Hard Street    +5    +5.5       -1       -1         3/32
   Drag Racing    +4    +4          0        0         1/32
   Road racing    +6    +6         -1.75    -1.75      Short Course
                                                          1/8 out
                                                         Long Course
                                                          1/16 in
From the tech articles section and copied into many a post like this!
You said you wanted a setup for hard street use, well its the second line in the table!
Si. :lala:
Old Apr 15, 2004 | 03:17 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
That's the specs I run. They work great and the tires seem to wear pretty even.
Old Apr 15, 2004 | 04:36 PM
5.0Camaro's Avatar
alright thanks, yea i saw that i just wasnt sure if anyone out there had a better set up or anything, and since i had the new upper strut mount and i can adjust more into them i didn't know if there was a better combo. But looks like i'll try that anything has to be better then stock.
deracer
Apr 11, 2016 12:04 AM
skip91
Sep 24, 2015 03:29 PM
redmaroz
Aug 16, 2015 11:40 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
