Boxed torque arm
Old Apr 23, 2004 | 04:18 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
Boxed torque arm
More like reinforced torque arm. I'm waiting for a new poly mount and decided to weld some 1/4" thick plates to the stock arm. I plan on getting an aftermarket arm later this year. I'm sure the poly mount will benifit more than the reinforced plates. just finished painting it.
Old Apr 23, 2004 | 06:08 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
Trying to post a picture.
Old Apr 23, 2004 | 08:04 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I hope you don't have driveshaft interference..
other than that.. looks good.
Old Nov 14, 2004 | 09:27 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Sorry to bring up an old post but...
Thats and interesting idea, to use the plates to help with flexing, i would use a little different design, triangles, but anyways
Did it interfear with the drive shaft as mentioned above?
Old Nov 14, 2004 | 09:39 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
It turned out, I had to remove the last two peices, because of interference. I should have welded to the other side.
Old Nov 15, 2004 | 02:56 AM
oil pan 4's Avatar
Car: 89 Firebird
Could you post how dimentions of that torque arm?
Or at least how long it is?
I realy want to build one but I don't have one over here with me to copy.
Old Nov 15, 2004 | 04:31 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
i have that torque arm in my car. its from a 6-speed ls1.little tougher,ALOT heavier. have you ever seen a broken torue arm? they always brake at the rear where it bolts to the rear end. thats where you should reinforce. even the bmr torque arms brake there. jacked up that a car that runs 10.20''s can rip apart a $330 torque arm. should be stronger but thats the way the cookie crumbles.......
Old Nov 15, 2004 | 11:47 AM
The Doc's Avatar
It's just the stock torque arm reinforced. Same length.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
