What is this called???
Old Apr 24, 2004 | 05:24 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
I know where it goes, but don't know the proper name for it. Will I need any special tools to put it on???
Old Apr 24, 2004 | 05:37 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
that
is a ball joint
vwdave's Avatar
Ball Joint.
Old Apr 24, 2004 | 06:35 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
You are going to need a press to install it.
Some people just use a BFH. I prefer to use a press though
Old Apr 24, 2004 | 06:55 PM
Car: '87 Camaro SC
Engine: 305 LG4
What is a BFH???
Old Apr 24, 2004 | 07:01 PM
Car: '87 Camaro SC
Engine: 305 LG4
Thanks...I'm trying to get this old clunker back on the road!!!
Old Apr 24, 2004 | 07:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by bulletboy29
What is a BFH???
In case you haven't figured it out yet, it is a mechanic's SUPER SECRET all purpose handy dandy tool that he would never get caught without. It's also known as a BIG F***ING HAMMER. The BIGGER, THE BETTER.
Old Apr 24, 2004 | 09:06 PM
Car: '87 Camaro SC
Engine: 305 LG4
LOL
Old Apr 28, 2004 | 07:05 PM
JohnnyCrash's Avatar
BFH...
I prefer the more technical term for a big hammer: "Ford wrench."
Old Apr 29, 2004 | 02:21 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Re: BFH...
Never heard that one, thats good
Old Apr 29, 2004 | 05:35 PM
Shagwell's Avatar
Car: projects.......
The press is very handy for those and Autozone has them on the loner tool program. - as for the BFH, some one on the boards has a quote saying..."When the only tool you own is a BFH, everything begins to look like a nail after a while..."
Old Apr 29, 2004 | 10:59 PM
topless89rs's Avatar
Engine: 5.slow
i'd be careful using a hammer. you could end up messing up the balljoint. a friend at school did it and he got about a block fro mschool and the ball actually popped out of the part it rotates in. so then he had to replace a bent tie rod and the balljoint. luckily he was just creeping away from a stop sign when it happened
Old Apr 30, 2004 | 01:30 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Re: BFH...
Not really related to the topic,but here goes.I heard this on an OLD 60s rerun of a nascar race on ESPN.Im mexican,but i still thinks its funny.Heres the scene 2 guys are pounding away at this chrome front bumper on some guys race car because its digging into the tire & the then the announcer says."Quote.....Theyre using a 20-lb sledge hammer to fix the damaged bumper or as i like to call it a mexican speed wrench....Unquote". Ahh the things you could say on TV before polictical correctness & janet jackson.
Old May 2, 2004 | 01:14 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Personally, I'd use the press due to dangerous nature of this particular job. If you bang around too much, you could inadvertantly knock the spring loose, which is extremely bad. But hey, that's just me. And the only thing to do with but hey is mow it and bail it!
Old Jul 7, 2004 | 03:58 PM
Car: '87 Camaro SC
Engine: 305 LG4
got it in
The BFH method didn't work for me, so I used a press from Autozone. Got it all back together and greased it and then noticed the rubber boot wasn't on there tight. I got to take it apart and do it again! Now if I could just hit the right bump to make the stock stereo come back on.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
