cutting your springs.
Old May 2, 2004 | 11:58 AM
treeohfive's Avatar
ok i know this can be done. what im curious to know is.....do i need to replace my shocks and struts for some odd reason..?
i doubt i do, but before i go yanking springs out and cutting a coil off ......i wanna know for sure if the stock ones will be fine (or will work for the time being)
Old May 2, 2004 | 04:12 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
they will work for the time being, just a rougher ride.
Old May 2, 2004 | 06:06 PM
treeohfive's Avatar
heh...did i mention this was going on a third gen? rough ride....if i wanted a smooth ride i wouldnt of gotton the car in the first place lol
Old May 3, 2004 | 01:51 AM
CrazyHawaiian's Avatar
Car: too many ...
I highly recommend you cut them in smaller increments than a coil at a time. I do mine 1/4 coil at a time. Just remember if you take too much off you can never go back. Also make sure your methods of cutting are not heat intensive. If you heat them up too much they will loose their stiff rate and become sloppy.
Old May 3, 2004 | 02:05 AM
treeohfive's Avatar
i was going to use a sawzall....not a angle grinder.....are there any ways around using a spring compressor...or is it definatly a good idea to use one. i know those suckers are under a decent amount of pressure and i dont want to loose an appendage due to not using a compressor.......
Old May 3, 2004 | 06:36 AM
Car: too many ...
I just used a really long rope. Pull and run!
Old May 4, 2004 | 01:13 AM
treeohfive's Avatar
lol now....since im cutting about an inch off the springs they should theoredicaly go in easier than they come out....will i need to compress them any when i go to re install them?? also....now did you undo both pivot bolts , then tied a rope to the spring and yanked it or what? lol
Old Aug 9, 2004 | 12:54 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
that gave me a damn good laugh crazy
Old Aug 9, 2004 | 01:07 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
LOL, that was great. Though not for from the truth.
For the rear, just unbolt the lower shock and drop the rear.
For the front I didnt use a compressor. I just let the A-arm swing down, but it still wouldn't come out so I got behind the A-arm, grabbed the spindle so my fingers could not be in the way of the springs, pull back hard and FIRE.
Getting the new ones in that way would be impossible without a compressor if they were stock height, if you cut yours you should be able to wedge it in and jack the a-arm back up to compress it.
Chris
Old Aug 9, 2004 | 01:25 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
A sawzall won't cut it, lol. I tired and it went through a blade without even making a scratch. And these were the good blades. Your going to want to use a cutoff wheel. Even with a 4" one spinning a 25,000rpm it takes 10 minutes to cut the front springs. They are made of a really good heat treated steel making then really hard.
Old Aug 9, 2004 | 03:35 AM
Car: too many ...
Hahaha I was just kidding about the pull and run (sorry guys). Actually the safest way to do it is chain the springs to the chassis and then pull em or pry em with something (I used a long rope hehe but the spring was chained down). That way they wont fly out and hit you. Yeah it does take a really long time to cut springs ...
If you're putting in drop springs you probably wont need a spring compressor or anything. Only if installing stock length springs, then I would worry about it. I use those weight jacks so the springs are usually very short (no issues at all).
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
