Need Help With Broken Sub Frame
Old May 13, 2004 | 05:47 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
Im looking to buy an 85 Z28 Camaro, the car itself is in great shape and it is only 1,000 dollars.
But the car has a BROKEN SUB FRAME.
I searched and couldnt find to much information on them all I seen was sub frame connectors. I dont know much about Sub Frames and was wondering if anyone knew how much a new one would cost, who makes good ones and if the car was worth buying with the broken sub frame.
Any Help would be much appreciated and sorry if I missed info already on this board.
Thank You
Old May 13, 2004 | 05:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on which part that's broken.
If it's the K-member, the thing that the engine sits on and the front suspension bolts to, you can replace it. If it's some part of the sheet metal reinforcement, you can probably weld it up.
Old May 13, 2004 | 06:34 PM
fyrechikyn's Avatar
pics would help alot rb83l69 is right if its sheet metal make sure its within specs and weld it up. if you need i can print out specs and either fax or mail em to you (sorry dont have acces to a scanner)
Old May 13, 2004 | 06:52 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
The Car is about 300 miles from me but I will e-mail the guy again and ask for some pictures then get back to you guys with them, all he told me was the sub frame was broken didnt say which part... He has been pretty cooperative so I should have them in a couple days. Thanks for the help.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
