Sticky back brakes
Old May 22, 2004 | 01:06 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Sticky back brakes
I changed my rear axle seal a couple of days ago. Now the pass. rear brakes stick. I have taken off the drum and sprayed it with brake clean as there was a bit of oil on the pads. Works great for the 1st bit then the brakes stick.
Any suggestions what to do? Get new pads?
LB9GTA
Old May 23, 2004 | 10:22 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
anyone?
Old May 24, 2004 | 10:14 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
brake drums
You may need to adjust the rear drums. I did it this weekend because my rear brakes were not grabbing. Just put the drum on and turn the adjuster wheel (via the little port on the inside) until you get a little big of drag on the drum, then back it off 12 clicks ( the drum will move freely). Make sure to check that your E-brake cable lever inside the the drum is not sticking, and that the return springs for the shoes are working too. Put the wheels back on and drive the car in reverse and brake a couple of times. I did it about 5-ten times while going in reverse and the self adjusters should take care of the rest.
sailtexas186548
Jan 19, 2016 12:21 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
