sphon sfc's
Old May 23, 2004 | 02:17 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
sphon sfc's
ok first let me say I searched and searched. does anyone have pics of sphon sfc's installed on thier car? the actual question is where do they get welded on to. thanks for any input
Old May 23, 2004 | 03:27 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
There's pics right on his site http://www.spohn.net//index.cfm?acti...d&contentid=10
Old May 23, 2004 | 06:10 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
that helps a little bit, but I'm not completely sure where they hook up to and what it looks like with a single cat (well no cat actually) application. and that dosen't really show where they hook up to in relation to the body of the car or any kind of reference point...other than the pics with the cat in them. I appreciate the link but on that site the sfc's just blend in with the rest of the underbody.
Old May 23, 2004 | 08:02 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Then I don't think you are looking very well...
it's pretty clear if you spend some time looking at them
Old May 23, 2004 | 09:23 PM
CaysE's Avatar
It's pretty simple really. The passenger side is the one with the taper at one end. If you look at the SFCs, one end has a welded plate with a hole in it. You take out the bolt holding the LCA in on the car and this is where the back of the SFC goes. With the bolt holding the back of the SFC on, you just start welding from the front every 10-12 inches or so along the length of it. Then you put in the cross braces.
Now go back and look at the pictures. You should get it by now, and you will definitely get it once you start putting them on. It's pretty straightforward. Good luck, and post pictures when you're done.
Old May 23, 2004 | 10:10 PM
waltersb's Avatar
I'm in the middle of working on the underside of the car, fixing the rust bits right behind the front wheels, then I will install mine (had them for over a year now)
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
