Who has done the C5 conversion?
Old May 25, 2004 | 08:24 AM
N2TRUX's Avatar
I have searched and read quit a bit, but haven't found much. I'm wondering how many of you have done the C5 brake conversion? I want to put big brakes on my 84 Z-28 but would prefer to discuss it with some one that's done it.
Old May 25, 2004 | 08:48 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what is it that you are wanting info on.
i haven't done C5, but i did C4. most everything is the same, the only diffrence is the bracketry.
Old May 25, 2004 | 09:11 AM
N2TRUX's Avatar
I'm still trying to sort out all the facts here. 1LE, C4,C5, LS1 and all are making my head spin.
Two quick questions though.
1-Will the 16" Z-28 (not IROC) wheels clear the 13" rotor/caliper combo? I plan to change to 18" wheels, but want to use the stock wheels while under construction.
2- What is the best rear brake conversion to match the front? I still have drum rears. Most threads discuss the front, and not much is mentioned about the rear.
Old May 25, 2004 | 09:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
1) I dont' know, Ebmiller did the 13" C4HD, and it cleared on IROC wheels, and 91/92 16" Z28 wheels, but i don't know the sizing on the C5's in comparison.
2) there are not alot of options, the later PBR calipers on thirdgens are descent. the Drum --> LS1 Rear is pretty easy.
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
Old May 25, 2004 | 09:58 AM
N2TRUX's Avatar
Thanks, thats a step in the right direction. I guess I'll just have to decide what conversion to do for the front, and see if my stock 16's clear. No biggie since I plan to upgrade anyway.
The rear conversion was my big concern. Some of the C5 conversions I have seen didn't have an E-brake. Since I am building this car with the intent of my daughter driving it some day, that wasn't an option.
I appreciate your patience, and the link...
Old May 25, 2004 | 10:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
There is also THIS Option, it will cost a little more, but is about the best rear brake setup i have seen.
Old May 25, 2004 | 10:24 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Are the fbody/c5 rear's the same size?
I swaped my entire rear with an LS1 rear so I got the moster brakes, that seemed easier than going from drum to disc plus I got posi and better gears
Old May 25, 2004 | 12:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've done both the 12" and 13" C4s but not the C5s....Those are Todd's baby: toddlsf.
The 13" C4s will clear stock Iroc and 16" RS alloy wheels but not GTA wheels. It's a great upgrade and I do recommend it highly.
As for the rear brakes, I recommend the 1LE/LT1 12" PBR brakes as they are the easiest to adapt to our cars and are more of a bolt on. I like the Wilwoods that Dewey linked you to but the 1LE/LT1s already have the e-brake setup so you won't have to come up with one. Baer has the rear PBR kits for $800 or so but I've seen them for around $600.
Ed
Old May 25, 2004 | 02:48 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
For those of us who like the 16 x 8 crosslace (or GTA) wheels, the C4 kit put together by EBM Industries (like that one, Ed?) is a good option...
Old May 25, 2004 | 11:36 PM
N2TRUX's Avatar
Chuck!- I have considered that option. There is a local guy that has an F-body salvage yard that I could get a decent deal from. What I don't like about that is the increased track width. I plan to have as much rubber as I can get on the back, but I want it all "under" the car.
ebmiller88- So considering what I have read of your post Ed, I assume you would suggest the 13" C4 HD up front and the 1LE/LT1 12" PBR for the rear. Am I correct in thinking the only difference between the C4 HD and C5 conversion, is the C5 has larger calipers?
Old May 26, 2004 | 01:12 PM
ebmiller88's Avatar
Right. I recommend those brakes for a great upgrade...and as for the calipers, basically yes: The HD rotors are a full 13" and the C5 rotors are 12.75" but they are thicker, 1.25" and the HDs are 1.1". That's really not a lot and won't make that much of a difference IMO.
The C5 calipers are indeed bigger and are also pin guided whereas the C4 calipers are pad guided. That's about it, and the C5 pistons are pretty close to the size of the C4 caliper pistons.
Ed
Old May 26, 2004 | 07:34 PM
N2TRUX's Avatar
Ed thanks a bunch. There is a lot of great info on this site, but it's a bit scattered out. Trying to get it all together to analize it has been a challenge. This will get me going in the right direction.
I guess what I need now is a 98+ rear axle to scavange brakes, posi, and gears from...
Old May 26, 2004 | 08:43 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I'd would get new rotors and new brake hoses if you go the junk yard route.
Old May 27, 2004 | 06:18 PM
N2TRUX's Avatar
I agree. I will just use the non-wear items, and use GM or aftermarket upgrades for brake pads and rotors....
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
