make it more quite
Old May 27, 2004 | 03:36 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
make it more quite
besides struts & shocks, whats a better way to make ur camaro quite when rolling over train tracks and surfaces of the like? just so much clank! clank! when rollin over that stuff.
Old May 27, 2004 | 03:37 PM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
Turn up the radio
Old May 27, 2004 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
subframe connectors.
half the noise is the car flexing... if you stiffen the car, the suspension has a chance to work and absorb the impacts.
Old May 27, 2004 | 03:42 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
whats a subframe connector, whats the cost, and is it easy 2 install?
Old May 27, 2004 | 03:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you must be new here
if you do a search on SFC you'll come up with a ton of detailed info.
in a nutshell, subframe connectors are metal bars that are bolted or welded under the car... they connect the front "frame" of the car with the rear.
these cars have no frame. the floorpan IS the car..... what these connectors do is connect the two points and stiffen the floorpan..
the car doesnt twist over bumps, so panels dont squeek.. it also handles better and just overall feels nicer.
avg cost is 100-250 depending on what ones you get, and where you buy them. installation is bolt on for some... but the better ones have to be welded on.
you can take it to a shop to have them welded... prices range wildly for that, some have it free, others paid close to 200 (and got ripped in my opinion.) i would consider 50-70 a fair price for install.
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
