how do i set the idler arm height????
Old May 27, 2004 | 05:41 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
as anyone who has rebuilt there steering knows there is some adjustment in the mounting of the idler arm assembly to the frame of the car. My question is how or where do i measure to set this thing correctly?? i presume that it is to be on the same level as the pitman arm, and thus make the draglink level to the car???
Old May 27, 2004 | 05:48 PM
Car: 1984 Firebird
Axle/Gears: 4.10
also does anyone have the correct specs to set things to caster camber, toe, etc....
i assume all i really need to do it myself is degree based level, and a good tape measure
the shops here are smacktards, last time i jad it aligned it was worse than when i took it too them
Old May 27, 2004 | 09:24 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
Here's the camber/caster info
https://www.thirdgen.org/techbb2/sho...ighlight=tires
Old May 27, 2004 | 11:15 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
You set the idler arm so that the center-link is parallel with the ground. With the wheels flat on the ground of course.
Old May 30, 2004 | 04:22 PM
Car: 1984 Firebird
Axle/Gears: 4.10
well i got all my parts replaced, discovered a couple things along the way........
car sat really tall in the front, i learned that the springs fro not rotated correctly in the control arms, its a bit lower now
my other discovery is quite disturbing........ the drivers side strut mount, had some damage, the rubber was torn about half the way around the metal part in the middle. naturally allowing some excess movement.
perhaps this is my vibration that has forced me to try 2 clutches 2 trannies, 3 driveshafts, and a different rearend. also different tires
Old May 31, 2004 | 04:27 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
at bottom http://www.fl-thirdgen.org/idlerarm.html
customblackbird
Aug 15, 2021 10:16 PM
Ghettobird52
Apr 21, 2020 08:44 PM
evilstuie
Apr 14, 2016 08:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
