neutral handling?
Old Jun 4, 2004 | 07:37 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
neutral handling?
anybody hit the right suspension tuning to get a neutral handling third gen z-28? so far i've got stock springs, bilstein struts, 34/24mm bars, monroe rears, sfc's, strut tower brace....and the car understeers. not badly, but enough at the extremes. i'm running in ssca autocross and some track days..just aligned the whole set-up and got a max -.5 camber, zero toe. should i get the eibach pros and koni rears to finish the package? don't give me textbook answers..i need practical, real world info from guys that really drive!!
Old Jun 4, 2004 | 08:09 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The easiest thing you can do is swap the rear swaybar out for a smaller one (like a 21mm) so that the rearend can be powered around corners better. You may also want to adjust tire pressure more - makes a big difference.
I run the 36mm/18mm combo - this is due to having a lot of power and wanting to steer the car with the throttle.
Old Jun 4, 2004 | 01:34 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I think that a smaller rear sway bar would increase the understeer by planting the rear better.
My suggestion is to work on the alignment first by installing Ground Control caster/camber plates. I can get up to -2.25 degrees of camber. If you have Bilstiens on the front I would put Bilstiens on the rear, though I would really recommend Koni Sports on the front and Bilstien or Koni Specials in the rear. I would also recommend a T2-R differential.
Old Jun 4, 2004 | 09:18 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
That helps your coming out of the corners, but hurts going in bigtime. Try putting the big bar back in, then lower your front compression and rebound forces.
92camaro350cci
Oct 14, 2015 09:29 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
RedLeader289
Sep 23, 2015 06:50 AM
Stroopwafel
Sep 11, 2015 06:38 AM
