Front Suspension Upgrades
Old Jun 4, 2004 | 11:13 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
I am taking my engine out this weekend and I figured this is a good time to do some front suspension upgrades. I am looking for a occasional driver and auto-x/solo 1 car. I have a ws6 car so I dont need a sway bar. What suggestions do you guys have for upgrades?
Old Jun 4, 2004 | 11:48 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
good struts, good springs, new steering stuff if needed, a wonder bar, poly (or del-a-lum) bushings. any further then that and youre talking tubular cross member and control arms
Old Jun 5, 2004 | 08:36 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If its a WS6, he should already have a wonderbar, but can get a larger from TDS, or adjustable from sphon.
For sure need subframes
Good struts
the billet strut mounts (cha ching)
adjustable panhard bar (depending on class)
poly bushings everywhere
Lower it with eibachs. (depending on class)
create a trans tunnel brace like "agood2.8" did.
Alot will depend on class you plan to run in. I'm in ESP, and I can get away with about 2x the mods I have now.
Old Jun 5, 2004 | 03:45 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
WS6's didnt get the wonderbar, just Irocs
I wish either of mine would have came with one...
Old Jun 6, 2004 | 10:01 PM
Car: 1988 T/A WS6
the first thing I plan on getting is Spohns Front End Rebuild kit. Should I put the kit in while the engine is out or wait until it goes back in?
Old Jun 8, 2004 | 12:28 PM
Car: 1988 T/A WS6
well...the engine is out and I noticed that my k-member is really beat. I am looking into a tublar k member...but... I am not sure how hard it would be to install...Does anybody have any advice? Thanks
Old Jun 8, 2004 | 11:05 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Wonder bar, strut tower brace, solid tie rod end sleves and different alignment specs like global west has. Everything else on ws6 is good enough. DO NOT replace your ws6 springs with ones that are softer / taller. Most replacment springs fit into this category, they are less responsive. But you SERIOUSLY need to replace all the old original parts FIRST if you want to do it right. You dont want to be the guy on the track showing off your car and then not finish the run because your old balljoint or tierod end breaks. Not pictured below are strut bushings, I got them shortly after taking this pic.
Old Jun 8, 2004 | 11:09 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
You gotta replace it all or make sure it works 100% if you want it to handle like new. Then your upgrades will make a real difference. The kit is good, the parts are easier to put on without an engine in the way.
Old Jun 13, 2004 | 04:13 PM
Firechicken91's Avatar
Car: 1991 Trans Am
Engine: 350c.i. TPI (coming soon: 357c.i. TPI screamer)
I'll be completely rebuilding my front end in the coming weeks. As it sits, the car has the F41 suspension package. My parts list includes Spohn adjustable wonder bar, Spohn billet strut mounts, Koni "Yellow" Sport adjustable struts, Eibach Pro-Kit springs, Spohn front end rebuild kit, poly tie rod and ball joint boots, and poly control arm bushings.
My question is, does anyone have any advice on the best way to remove the old bushings from my control arms and install the new poly bushings? I'm a GM technician, so tools are not a problem, but our front end guy says it's not worth the trouble (huge pain in the a**) or risk of damaging the control arms. Help please! Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
