Lakewood Traction Action bars .vs. ride height
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I installed a set and set them up according to instructions. For some reason my rear end sits a full 1" lower than the front. The only thing I did in the front was change the motor mounts and replace the front sway bar end bushing kit. What gives?
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
my situation is the opposite.the rear of my car is 1" higher and i folled the instructions too.what gives lmao
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Wow, this was a long time ago.
I later found out that by turning the rear springs it raises or lowers the rear a bit. I probably just moved the springs while I was installing the traction bars.
i readjusted mine today got em close to within 1/2 inch higher in the rear than the front.i can live with that
