replace brake reservoir???
Old Jun 10, 2004 | 09:49 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
has anyone replaced their brakereservoir? yellow plastic looks like crap. if so with what and where do I get a new one. Anyone with pictures would be great.
Old Jun 14, 2004 | 01:10 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
No pics....
But the change is pretty easy. There are 2 bolts holding the complete assembly to the booster. So drain the fluid into a plastic container. Watch spillage on your paint, brake fluid might as well be called paint stripper. Then disconnect the 2 brake lines coming out the side and push them out of the way. The lines should flex enough that they won't break, just push easy, and make sure they aren't rusty. Then unbolt the master cylinder and resevoir. Comes free pretty easily. Get another one from Napa or autozone and turn in your old one for the core deposit.
Old Jun 14, 2004 | 02:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: No pics....
uhh, or you could just pull the old one off, and press the new one on.
just be sure not to spill brake fluid.
and if you let any air in the master cyl, you will need to bench bleed it. if your careful and you let some fluid stay in it, you wont have to do that though
Old Jun 14, 2004 | 03:27 PM
Spdfrk1990's Avatar
I was wondering that also if there is anywhere just to get the reservoir.
Old Jun 14, 2004 | 03:41 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the "HELP!" section of your local auto parts store.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
