suspension questions
Old Jun 13, 2004 | 12:27 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
I was driving around today, slightly over the speed limit, and drove over a bump. The car bottomed out 3 times, scraping either the frame or front clip/ air dam. The car is rather low mileage. I was wondering if just letting the car sit for 18 years has weakend the springs/shocks. Whats a decent shock or spring company to go with?
Old Jun 13, 2004 | 01:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sounds like your springs are shot. Sitting still will not kill springs but that doesn't mean yours aren't worn out. Chances are your shocks are shot as well. Try a few searches on which ones to go with. You will find all kinds of info and pics to help make a good decision that best fits your driving style.
Old Jun 13, 2004 | 05:09 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
bouncing is caused by worn worn shocks/struts.
sagging, "soft" ride, body lean, etc are caused by worn springs...
Old Jun 14, 2004 | 06:46 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Time alone can kill springs. They are the only thing that holds your car off the suspension. Even just sitting they start to sag over time. Unless your shocks are all rusted up, inside or outside, they should still be alright because they only wear with usage.
Old Jun 14, 2004 | 07:18 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Springs are probably fine. The shocks and struts need to be replaced.
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
